![]() | Home > Wheels & Tyres > Is it easy to change the wheel studs (FRC7577) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6047 ![]() ![]() |
Normally easy, as they are just pressed in, but if they don't want to come out you may have work a bit harder, but you will have to strip the bearings.
Andy |
This will help you
http://forums.lr4x4.com/index.php?showtopi...el+%2Bstud Andy |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
cheers Andy,
I don't have 'permission' to open most of the thread ![]() |
The basics are
Jack up Remove wheel Remove drive flange Remove brake calliper Remove wheel bearing Remove brake disc with hub. Then smack out the old studs, tap in new studs Rebuild Andy |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
But for wolf rims they don't need changing....
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Depends which studs you have, on older vehicles, the studs are slightly shorter. And wolf wheels are slightly thicker, so longer studs are needed.
It'll be cool not to have to change them.
Mine came with the 5.5 ice cream steel's, are the studs good for the Wolf rim? Got a quote for the stealer ... LRFC7577 17.62 each ... total with VAT £354.19 ![]() |
