Home > Wheels & Tyres > Is it easy to change the wheel studs (FRC7577)
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
I'm generally ok with spanners ... but no mechanic.
Just wondering what is involved in changing the wheel studs for longer ones.
i.e. for wolf rims
Post #289310 10th Dec 2013 10:49pm
landy andy
Normally easy, as they are just pressed in, but if they don't want to come out you may have work a bit harder, but you will have to strip the bearings.
Andy
Post #289314 10th Dec 2013 10:52pm
landy andy
Post #289315 10th Dec 2013 10:55pm
ti-fat-man
cheers Andy,
I don't have 'permission' to open most of the thread Crying or Very sad
Post #289319 10th Dec 2013 11:04pm
landy andy
The basics are
Jack up
Remove wheel
Remove drive flange
Remove brake calliper
Remove wheel bearing
Remove brake disc with hub.
Then smack out the old studs, tap in new studs
Rebuild
Andy
Post #289327 10th Dec 2013 11:09pm
But for wolf rims they don't need changing....
Post #289393 11th Dec 2013 8:48am
Leenorthants
Depends which studs you have, on older vehicles, the studs are slightly shorter. And wolf wheels are slightly thicker, so longer studs are needed.
Post #289421 11th Dec 2013 10:12am
ti-fat-man
It'll be cool not to have to change them.
Mine came with the 5.5 ice cream steel's, are the studs good for the Wolf rim?
Got a quote for the stealer ... LRFC7577 17.62 each ... total with VAT £354.19 Shocked
Post #289653 11th Dec 2013 10:47pm
