![]() | Home > Technical > Prop Shaft Phasing - Double Cardon |
| Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329
WTF, most of that went straight over my head
Sounds like this is one for the geeks! |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I wouldn't have thought the front double CV shaft should be out of phase, as the double CV bit eliminates the "diff nose not pointing at the transfer box flange" problem
edit: I had an equippe4x4 prop on my old 90, and I can't remember whether it was in or out of phase edit2: just checked some old photo's of my prop, and it was in line. |
| SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388
Thanks - I'm really looking for somebody who can help with the science bit. Props are usually set in-phase for all except the Defender and RR
Are there no 'geeks' out there who can help. I may just have to do it by experimentation
Experimantation is the mother of innovation! go for it.
I'll start with the rear prop as that is definitely wrongly phased and go from there
Got to ask.... how/why are your props out of phase? has some imp been fiddling, or do you have some drivetrain vibrations? (since the 2" lift?)
The lift could be the problem... tried castor corrected radius/trailling arms instead? (front ones will help the hansling if your lift is too high) |
| DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68
Am I right in saying that phasing only applies to a 110 and not a 90?
Any advice appreciated. Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
I wouldn't think the wheelbase would make any difference... although the longer the prop, the shallower the UJ angles.... hmmm.... i don't know now... confusing myself!
Thanks for the reply Jim. My reason for asking is that I read an article posted elsewhere on this forum, which says phasing only affects RR and 110 Defenders.
The link is shown below. http://s884.photobucket.com/user/yostumpy/...8.jpg.html What is confusing me though is this, it goes on to say later in the article that in-line flanges should be in phase, but out of line flanges should be out of phase. Well, the out of line flanges certainly would cover the front prop on a 90 - hence my confusion. Hope that makes sense! Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
