Home > Technical > Prop Shaft Phasing - Double Cardon
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I have been reading up on previous posts about phasing of the props. The long and short of it is that the 'science' says the rear prop should be in phase (as the transfer box flange and diff flange planes are parallel to one another), whilst the front prop should be out of phase as the flange planes are not parallel to one another.
Currently the rear prop is 45 degrees out of phase and I will get that sorted. The front prop is A DOUBLE CARDON and is 90 degrees out of phase. I checked my original front prop and that had been set at 45 degrees out of phase.
So for the front prop - does the same logic still apply for double cardon as for a conventional prop - ie should it be out of phase? And secondly, does anyone have any recommendations for the angle of phase. I'm thinking to turn this back from 90 degrees to 45 degrees as this seems to be the received wisdom from articles I have read
I have a 2inch suspension lift
Post #288371 7th Dec 2013 1:19pm
Norm4n
WTF, most of that went straight over my head
Sounds like this is one for the geeks!
Post #288384 7th Dec 2013 2:42pm
I wouldn't have thought the front double CV shaft should be out of phase, as the double CV bit eliminates the "diff nose not pointing at the transfer box flange" problem
edit: I had an equippe4x4 prop on my old 90, and I can't remember whether it was in or out of phase
edit2: just checked some old photo's of my prop, and it was in line.
Post #288407 7th Dec 2013 5:28pm
SteveS
Thanks - I'm really looking for somebody who can help with the science bit. Props are usually set in-phase for all except the Defender and RR
Post #288487 7th Dec 2013 11:14pm
SteveS
Are there no 'geeks' out there who can help. I may just have to do it by experimentation
Post #290115 13th Dec 2013 4:51pm
Experimantation is the mother of innovation! go for it.
Post #290145 13th Dec 2013 6:28pm
SteveS
I'll start with the rear prop as that is definitely wrongly phased and go from there
Post #291561 19th Dec 2013 12:01am
Got to ask.... how/why are your props out of phase? has some imp been fiddling, or do you have some drivetrain vibrations? (since the 2" lift?)
The lift could be the problem... tried castor corrected radius/trailling arms instead? (front ones will help the hansling if your lift is too high)
Post #291565 19th Dec 2013 12:07am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Am I right in saying that phasing only applies to a 110 and not a 90?
Any advice appreciated.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #291608 19th Dec 2013 11:30am
I wouldn't think the wheelbase would make any difference... although the longer the prop, the shallower the UJ angles.... hmmm.... i don't know now... confusing myself!
Post #291609 19th Dec 2013 11:35am
DefenderJon
Thanks for the reply Jim. My reason for asking is that I read an article posted elsewhere on this forum, which says phasing only affects RR and 110 Defenders.
The link is shown below.
http://s884.photobucket.com/user/yostumpy/...8.jpg.html
What is confusing me though is this, it goes on to say later in the article that in-line flanges should be in phase, but out of line flanges should be out of phase. Well, the out of line flanges certainly would cover the front prop on a 90 - hence my confusion.
Hope that makes sense!
Post #291611 19th Dec 2013 11:46am
