Home > Technical > Question about soft top windscreen rail fixing
SailingTom
Hi there, I searched the forum and couldn't find anything similar.
Basically I've just bought a 2011 truck cab and will be changing it to a mohair soft top, my question is im having the frame made and galvanised by a specialist and getting the Exmoor hood. Can any of you point me towards where I can purchase the front header rail? Its normally aluminium, but I cant find a seller anywhere of one for a puma.
Any help would be greatly appreciated.
Thanks Tom Smile
Post #286000 28th Nov 2013 4:26pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi Tom, There`s a couple on Ebay at the moment. See item eBay Item No. 171139698158 and item eBay Item No. 281214944520. Which one you need will depend on how the hood fixes to the header rail not whether it is a Puma or not. There is the early type to suit the normal canvas type hood and the later type to suit the newer PVC wolf style.Not sure what style your mohair hood will be. Perhaps exmoor trim can advise which type header you need? Hope this helps! Cheers! Donald Smile
Post #286008 28th Nov 2013 4:39pm
Leenorthants
Iirc they are the same, the bar will need the clamps, Like these http://www.ebay.co.uk/itm/Land-rover-90-11...1038277386
Post #286016 28th Nov 2013 4:55pm
SailingTom
Thanks Guys, its this hood by the way; http://www.mm-4x4.com/defender-90-full-hoo...3540-p.asp
Ill give Exmoor trim a ring next week to confirm.
Cheers Tom
Post #286018 28th Nov 2013 5:01pm
dondiddy
Hi Tom, Just noticed that Exmoor trim actually list the header rails for sale as well! Part number for later type which your hood should be is EXT221-37. Costs about £88 or so plus the usual drat and carriage. Not that much more than a used one so would probably buy new! Smile
Post #286020 28th Nov 2013 5:09pm
SailingTom
Thanks Donald
Might as well get a new one then as doesn't seem much more, I must be mad going to swap it over this time of year Wink
Post #286021 28th Nov 2013 5:16pm
I got a load of soft top bits from All wheel trim in Witney.... much friendlier (IMO) than exmoor trim.
Edit: Witney, not Abindon.. my bad.
Post #286050 28th Nov 2013 7:43pm
Martin
Site Admin
^^ +1 - top guys Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #286051 28th Nov 2013 7:45pm
Leenorthants
All wheel trim are excellent!
Post #286055 28th Nov 2013 8:02pm
SailingTom
Thanks Every one,
Ill give them both a ring to see, only reason for favouring the Exmoor myself was that in the pictures it comes a bit further down the sides for the push on clips, as my pickup has a rear 3/4 mohair hood on at the moment and the poppers are on the alloy further down as opposed to the steel capping's so wanted to use those rather than having another set lower down.
Ill speak with them anyway to discuss it and see if they do something similar.
Cheers for all the help, have been missing a soft top since I got rid of my old series and love the look of a defender with the sides rolled up! Very Happy
Post #286346 29th Nov 2013 8:43pm
Like mine....
Post #286359 29th Nov 2013 9:39pm
jimsadventure
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Nice looking truck mate Thumbs Up
Post #286364 29th Nov 2013 10:04pm
