![]() | Home > Technical > Question about soft top windscreen rail fixing |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733 ![]() ![]() |
Hi there, I searched the forum and couldn't find anything similar.
Basically I've just bought a 2011 truck cab and will be changing it to a mohair soft top, my question is im having the frame made and galvanised by a specialist and getting the Exmoor hood. Can any of you point me towards where I can purchase the front header rail? Its normally aluminium, but I cant find a seller anywhere of one for a puma. Any help would be greatly appreciated. Thanks Tom ![]() |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Hi Tom, There`s a couple on Ebay at the moment. See item eBay Item No. 171139698158 and item eBay Item No. 281214944520. Which one you need will depend on how the hood fixes to the header rail not whether it is a Puma or not. There is the early type to suit the normal canvas type hood and the later type to suit the newer PVC wolf style.Not sure what style your mohair hood will be. Perhaps exmoor trim can advise which type header you need? Hope this helps! Cheers! Donald
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Iirc they are the same, the bar will need the clamps, Like these http://www.ebay.co.uk/itm/Land-rover-90-11...1038277386
Thanks Guys, its this hood by the way; http://www.mm-4x4.com/defender-90-full-hoo...3540-p.asp
Ill give Exmoor trim a ring next week to confirm. Cheers Tom |
Thanks Donald
Might as well get a new one then as doesn't seem much more, I must be mad going to swap it over this time of year ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
I got a load of soft top bits from All wheel trim in Witney.... much friendlier (IMO) than exmoor trim.
Edit: Witney, not Abindon.. my bad. Last edited by diesel_jim on 28th Nov 2013 7:47pm. Edited 2 times in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
^^ +1 - top guys
All wheel trim are excellent!
Thanks Every one,
Ill give them both a ring to see, only reason for favouring the Exmoor myself was that in the pictures it comes a bit further down the sides for the push on clips, as my pickup has a rear 3/4 mohair hood on at the moment and the poppers are on the alloy further down as opposed to the steel capping's so wanted to use those rather than having another set lower down. Ill speak with them anyway to discuss it and see if they do something similar. Cheers for all the help, have been missing a soft top since I got rid of my old series and love the look of a defender with the sides rolled up! ![]() |
Like mine....
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 ![]() ![]() ![]() |
Nice looking truck mate
