![]() | Home > Puma (Tdci) > New 90 tdci SIDE LAMP PROBLEM. |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 ![]() ![]() |
Keeps blowing the fuse on the passengers side, any clues ?
Think it could be a trapped wire but thought I would ask just in case someone has been there already. Still blowing the fuse with all the bulbs out on the passengers side. Any help most appreciated. Andy. www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
Mucky tow electrics maybe
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065 ![]() ![]() |
This might be related?
http://www.defender2.net/forum/topic11348.html or http://www.defender2.net/forum/topic2156.html Last edited by DAZ110 on 6th Nov 2013 6:21pm. Edited 1 time in total |
Albert s Member Since: 20 Oct 2013 Location: Nth lincs Posts: 41 ![]() ![]() ![]() |
I am sure you are correct with a trapped wire
Check rear numberplate light ....
Thanks gents, I will take a look in the morning.
It only affects the passengers side lights, number plate lamp and the speedo lights. It's only done 130 miles so probably about right for L/Rover electrics. ![]() www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
Well spot on that man, but this was a fault in the loom where the speaker had been bolted down . ![]() I will advise other owners to check the number plate lamp as mine had had a small fire behind the passengers side rear speaker box (standard factory), O.K. this is a fused lamp but why ? We are repairing this ourselves to save the pain of loosing it to the dealer for days, we have had to replace the number plate lamp as well because it was melted. ![]() www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1388 ![]() ![]() ![]() |
......... fit a LED one . See www.mobilecentre.co.uk Putting Dreams on Drives at JLR Solihull.. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Shame that isn't a straight swap and requres hole drilling and wiring loom butchery. Pete |
The RDX version from Bolt on Bits is a straight replacement apart from connecting the wires which is easily done.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Not quite sure why I would want to fit an LED number plate lamp,
![]() ![]() We have just replaced the number plate lamp with one from our stock and all is well. ![]() www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Didn't spot this when you posted it. Mine also did this. Recommend getting one of those led replacements.
Because they seem better made. I know they are a bit chavy but they don't set fire to your truck.
Hear what you say but I don't want to "chav" it up as I will only have it till Jan and it's new. Andy.
