Home > Puma (Tdci) > New 90 tdci SIDE LAMP PROBLEM.
AJS4X4
Keeps blowing the fuse on the passengers side, any clues ?
Think it could be a trapped wire but thought I would ask just in case someone has been there already.
Still blowing the fuse with all the bulbs out on the passengers side.
Any help most appreciated. Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #280083 6th Nov 2013 6:04pm
mk1collector
Mucky tow electrics maybe
Post #280085 6th Nov 2013 6:11pm
DAZ110
This might be related?
http://www.defender2.net/forum/topic11348.html
or
http://www.defender2.net/forum/topic2156.html
Post #280087 6th Nov 2013 6:14pm
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I am sure you are correct with a trapped wire Razz
Post #280089 6th Nov 2013 6:21pm
Check rear numberplate light ....
Post #280091 6th Nov 2013 6:26pm
AJS4X4
Thanks gents, I will take a look in the morning.
It only affects the passengers side lights, number plate lamp and the speedo lights.
It's only done 130 miles so probably about right for L/Rover electrics. Rolling Eyes Andy.
Post #280114 6th Nov 2013 7:31pm
AJS4X4
Well spot on that man, but this was a fault in the loom where the speaker had been bolted down . Bow down
I will advise other owners to check the number plate lamp as mine had had a small fire behind the passengers side rear speaker box (standard factory), O.K. this is a fused lamp but why ?
We are repairing this ourselves to save the pain of loosing it to the dealer for days, we have had to replace the number plate lamp as well because it was melted. Shocked Andy.
Post #280266 7th Nov 2013 10:24am
Cool
Post #280267 7th Nov 2013 10:25am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
fit a LED one . See www.mobilecentre.co.uk Putting Dreams on Drives at JLR Solihull..
Post #280305 7th Nov 2013 12:49pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Shame that isn't a straight swap and requres hole drilling and wiring loom butchery.
Pete
Post #280477 7th Nov 2013 11:41pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The RDX version from Bolt on Bits is a straight replacement apart from connecting the wires which is easily done. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #280484 8th Nov 2013 12:34am
AJS4X4
Not quite sure why I would want to fit an LED number plate lamp, Rolling Eyes Or am I missing something. Exclamation
We have just replaced the number plate lamp with one from our stock and all is well. Thumbs Up Andy.
Post #280498 8th Nov 2013 7:55am
RobKeay
Didn't spot this when you posted it. Mine also did this. Recommend getting one of those led replacements.
Post #280516 8th Nov 2013 10:09am
RobKeay
Because they seem better made. I know they are a bit chavy but they don't set fire to your truck.
Post #280517 8th Nov 2013 10:10am
AJS4X4
Hear what you say but I don't want to "chav" it up as I will only have it till Jan and it's new. Andy.
Post #280522 8th Nov 2013 10:53am
