![]() | Home > Maintenance & Modifications > aligning doors |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
Door hinges. They obviously attach the the door and the body. If aligning the doors would I assume you adjust / loosen the hinge / door had or the hinge / body part or a combination of both?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Not forgetting you might need to adjust the door catch as well. 1999 Defender TD5 110
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
I found aligning the doors quite a pain on your own. Enlist a keen mate it makes it a lot easier. There's a great feeling about making them shut well.
I slack everything off then hold it in place while a mate tightens it up. Adjust the catch and away you go. |
great. thank you.
no worries about finding doors haven't been painted behind hinges? just got the one door to do. will have to try the wooden blocks first and then call in the calvary if I can't do it by myself. ![]() |
