Home > Maintenance & Modifications > aligning doors
Caterham
aligning doors
Door hinges. They obviously attach the the door and the body. If aligning the doors would I assume you adjust / loosen the hinge / door had or the hinge / body part or a combination of both?
Post #278973 2nd Nov 2013 10:14pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Most of the adjustment is on the bulkhead side of the hinge, so I would start there.
Can be a bit of a pain to line up, I normally loosen off the bulkhead fixings, close the door and use thin wood packers to the bottom of the closed door where required to aline, then tighten up the bulkhead fixings.
N.
Post #279038 3rd Nov 2013 9:52am
excossack
Not forgetting you might need to adjust the door catch as well. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #279048 3rd Nov 2013 10:16am
RobKeay
I found aligning the doors quite a pain on your own. Enlist a keen mate it makes it a lot easier. There's a great feeling about making them shut well.
I slack everything off then hold it in place while a mate tightens it up. Adjust the catch and away you go.
Post #279054 3rd Nov 2013 10:42am
Caterham
great. thank you.
no worries about finding doors haven't been painted behind hinges?
just got the one door to do. will have to try the wooden blocks first and then call in the calvary if I can't do it by myself. Thumbs Up
Post #279212 3rd Nov 2013 9:11pm
