Home > Maintenance & Modifications > Locking Your Tailgate
I want to be able to lock my tailgate and can only think of putting padlocks through each of the catches:
has anyone come up with alternative solution?
If not, has anyone got a good supplier for 8 padlocks all keyed alike?
Post #276343 24th Oct 2013 3:30pm
leeds
You can get sets of 3 or 4 padlocks keyed alike in the DIY sheds.
To get 8 padlocks keyed alike is slightly more unusual.
I know Charles Watson ironmongers in Halifax can get padlocks keyed alike. Eight padlocks keyed alike is most likely a special order and may well cost £££s
Brendan
Post #276350 24th Oct 2013 4:05pm
How about 8 combination locks with adjustable code that match?
Not cheap again though but might be an easier option. Keys can be a pain anyway. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #276353 24th Oct 2013 4:13pm
Cheshire110
I wonder if it would be possible to use something like this?:
Would require some modification though, but I'd imagine it's possible.
http://mobile.maplin.co.uk/module.aspx?moduleno=12303 Cheers, David
Post #276355 24th Oct 2013 4:15pm
Why 8 padlocks out of interest ?
Post #276366 24th Oct 2013 4:47pm
Any good locksmith should be able to supply any number of keyed-alike padlocks. If possible get marine-quality stainless which will last longer.
Post #276369 24th Oct 2013 4:58pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
What blackwolf says ... but you can also find them on ebay, search for "keyed alike padlocks"
Post #276506 25th Oct 2013 5:30am
SteveG
2005 Defender 90 Td5 CSW Belize Green
You could fit some padlock hasps, one on each side...
[img]http://www.ebay.co.uk/itm/KEYED-ALIKE-DISCUS-PADLOCKS-WITH-SECURITY-VAN-HASP-LOCK-/310335803062[/img]
Or even modify a long throw deadbolt to fit each side. This would need some fabricating though..
[img]http://www.keylocksmithcompany.com/deadbolt-installation/4556598836[/img]
Also if you don't need drop down function of tailgate you can easily modify it to be swing open and then you just need one of these on one side only...
[img]http://lockitt.com/TrailerDoorLocks.htm[/img]
Post #276507 25th Oct 2013 6:18am
If you fit a lockable swing-away wheel carrier on the back, it will have the effect of locking your tailgate (and with a single lock). Most will also prevent a canopy flap from being opened, though usually if the wheel is removed from the carrier the canopy can be opened.
A padlock through the antiluce is as secure as a hasp and staple.
Post #276529 25th Oct 2013 7:52am
Thanks some good food for thought Thumbs Up
Not a fan of combination locks and if I get all locks keyed alike then I will only need a single key for all of them.
Had definitely not considered something like that, so I've had a look but ruled it out on two grounds - it's too far away from the KISS principle and at that price point I would be concerned of it's long term reliability.
Two for the tailgate
Two for the MSS drawer
Two for dog cage
One for the awning
One for the spare wheel
Thinking about it it might be better to go for 10 and have two spare Laughing
...and I've just had a thought about the seat boxes - so there's another two!
Thanks - didn't know about these before so after your pointer I've done a little research and decided that these do look right for my intended use Thumbs Up
Have decided against a swing away carrier for the time being - struggling to find one i like (single pivot) that is compatible with a rear step bumper and Patriot offside ladder.
blackwolf wrote:
...but you can also find them on ebay, search for "keyed alike padlocks".
Thanks - think I have identifed the supplier and make on ebay unless anyone has had bad experiences of either:
IFAM Marine Padlock - http://www.ebay.co.uk/itm/230974242781?ssP...1438.l2649
I just need to size up the shackle diameters to get the largest size that will fit.
Post #276545 25th Oct 2013 8:47am
