Home > Td5 > Rear power - purple/green
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have seen all the posts about the purple wire in the rear offside light box that provides always on 12v in Pumas.
In my TD5 I have a purple/green wire (with an associated black wire), it doesn't seem to have any power on it so wonderered which fuse I should check. I assume it should be powered in the same way as the Pumas..?
Simon
Post #276184 23rd Oct 2013 9:48pm
From memory, it's the 20amp fuse for the towing electrics under the drivers seat - second one up from the bottom in this picture:
 Darren
Post #276214 23rd Oct 2013 11:04pm
couplands
Thanks, I've checked all those and they seem intact.
Is this powered all the time, or is it only powered when the engine runs? I found something in the user manual that suggests it may only be when the engine runs.
Will check tomorrow.
Simon
Post #276219 23rd Oct 2013 11:15pm
It should be permanent live. It certainly is in my '05 TD5 and everybody else who's used them seems to have found the same. Darren
Post #276221 23rd Oct 2013 11:19pm
couplands
Hmm, I'm wondering if I have got the right wire. This one is green/purple, not solid purple, so I might be looking at the wrong one. A job for tomorrow.
Simon
Post #276224 23rd Oct 2013 11:29pm
Martin
Site Admin
If it's mostly green with a thin purple stripe, it's a brake light feed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #276242 24th Oct 2013 9:08am
couplands
Yes, realised I'd picked up the brake light (I assume the 3rd light in the rear window, mine's a van so not used)... Embarassed if I pressed the brake peddle it did light my work light..!
I found the purple wire, actually covered in a corrugated conduit, however it's still not working. Anyway, I'm running a 2 way switch from the front to rear so I don't need the rear power just yet.
Simon
Post #276433 24th Oct 2013 8:12pm
