![]() | Home > Td5 > Rear power - purple/green |
From memory, it's the 20amp fuse for the towing electrics under the drivers seat - second one up from the bottom in this picture:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 24th Oct 2013 9:28am. Edited 1 time in total |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Thanks, I've checked all those and they seem intact.
Is this powered all the time, or is it only powered when the engine runs? I found something in the user manual that suggests it may only be when the engine runs. Will check tomorrow. Cheers Simon |
It should be permanent live. It certainly is in my '05 TD5 and everybody else who's used them seems to have found the same. Darren
Hmm, I'm wondering if I have got the right wire. This one is green/purple, not solid purple, so I might be looking at the wrong one. A job for tomorrow.
Cheers Simon |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
If it's mostly green with a thin purple stripe, it's a brake light feed.
Yes, realised I'd picked up the brake light (I assume the 3rd light in the rear window, mine's a van so not used)...
![]() I found the purple wire, actually covered in a corrugated conduit, however it's still not working. Anyway, I'm running a 2 way switch from the front to rear so I don't need the rear power just yet. Cheers Simon |
