Home > Maintenance & Modifications > Duralac galvanic corrosion jointing compound
ericvv
I will shortly need to use some galvanic corrosion paste for SS and alu, and here in Switzerland that appears difficult to find. Rolling Eyes I have googled it and come up with Duralac anti-corrosion jointing compound. I can order this in the UK via internet, but before I do so, can someone confirm that this is the right paste to use?
Thanks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #275817 22nd Oct 2013 1:29pm
Tiger
Hope so as it's what I've used
Post #275819 22nd Oct 2013 1:38pm
hi Eric
that's what i used to sort the 8700s, I can bring some over for you if you can wait a couple of weeks
Post #275820 22nd Oct 2013 1:39pm
ericvv
Post #275822 22nd Oct 2013 1:47pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
It's pretty common in aviation for sticking aluminum skins together. Should be reasonably good 1998 110 300Tdi White Hard Top
Post #275824 22nd Oct 2013 2:31pm
VeeTee
Netherlands
That's the stuff, really good, I used to use it for installing S/S harware on aluminum masts on sailing boats. Cheers, Vincent
MySite
Post #275843 22nd Oct 2013 3:54pm
MartinK
I was going to use Duralac, but in the end used ACF-50 Corrosion-Block Grease. Seemed to work OK, but it's only been a year, so no long-term view as yet...
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #275845 22nd Oct 2013 4:03pm
