![]() | Home > Maintenance & Modifications > Duralac galvanic corrosion jointing compound |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
I will shortly need to use some galvanic corrosion paste for SS and alu, and here in Switzerland that appears difficult to find.
Thanks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Hope so as it's what I've used
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
hi Eric
that's what i used to sort the 8700s, I can bring some over for you if you can wait a couple of weeks |
replied to your PM.
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
That's the stuff, really good, I used to use it for installing S/S harware on aluminum masts on sailing boats. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
I was going to use Duralac, but in the end used ACF-50 Corrosion-Block Grease. Seemed to work OK, but it's only been a year, so no long-term view as yet...
Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| All times are GMT |
