Home > In Car Electronics > Stereo Install Help...
CEEGEE
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
I have read Papa Lazarou thread which gave me the confidence to install a stereo in my 2006 TD5 - its never had one before.
I have sorted the everything around the HU, and that's all fine, but have come to remove facia below wiper motor and there are no speaker wires.
Should they just be "hanging there" or do they need digging out - I thought they would be there on this model year.
Any help welcome...
Post #274561 17th Oct 2013 4:10pm
Have a look at nearest the firewall / bulkhead. I believe LR are good at taping them down just out of sight. Probably hidden. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #274563 17th Oct 2013 4:31pm
CEEGEE
Had a good dig around and can see wires coming out of loom to feed wiper motor, but nothing else.
Should they be there on a '56 reg car??
Thanks
Post #274566 17th Oct 2013 4:40pm
As far as if am aware some do and some don't. You can add your own though which wouldn't be too difficult, also giving you the chance to use high quality wire which will be useful. ____\We|Will|Win/___
Post #274568 17th Oct 2013 4:49pm
barbel jim
Would have thought so ......... Do you have the other wires for the head unit ??? It is pretty simple to run new wires for the fronts anyways Thumbs Up Just run them in this void simple. IIRC ordginal wires came down from up by the wiper motor. Think I can just make then out tapped up. 2 other black wires are for old mobile phone aerial Whistle
Post #274569 17th Oct 2013 4:52pm
CEEGEE
Okay, plot thickens - I can see that the front left and right "leave" the big black plug, but not sign of them by the wiper motor - I am just going to re-run a new wire, then as you say, I can put in better quality.
Now for the scary bit - cutting a hole in the trim Big Cry
Post #274578 17th Oct 2013 5:43pm
If your not the only owner it may be possible that they were cut off. Shocked ____\We|Will|Win/___
Post #274580 17th Oct 2013 5:51pm
Papa Lazarou
As Steve said earlier, they are probably taped up somewhere out of sight. I found the passenger side ones easily enough but the driver's side were well hidden - It must have taken me almost an hour to find them Banging Head Eventually I found them taped to the back of a loom up against the bulkhead. The connectors on the end of the wires had been completely taped over so I couldn't see them. Unwrapping the tape in that confined space was fun! Laughing
I was initially worried about cutting the trim too, but if you follow Jim's advice in my thread you won't go far wrong Thumbs Up
Post #274860 18th Oct 2013 4:50pm
CEEGEE
Thanks for all the help - stereo now in and working fine - I did end up finding the drivers side speaker wire, but re-threaded a new wire for the passenger side Thumbs Up
Need to decide on the next project now Very Happy
Post #275079 19th Oct 2013 5:01pm
Glad it's going well. Thumbs Up ____\We|Will|Win/___
Post #275105 19th Oct 2013 7:46pm
Papa Lazarou
Thumbs Up
Post #275194 20th Oct 2013 9:20am
