![]() | Home > In Car Electronics > Stereo Install Help... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Have a look at nearest the firewall / bulkhead. I believe LR are good at taping them down just out of sight. Probably hidden. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135 ![]() ![]() ![]() |
Had a good dig around and can see wires coming out of loom to feed wiper motor, but nothing else.
Should they be there on a '56 reg car?? Thanks |
As far as if am aware some do and some don't. You can add your own though which wouldn't be too difficult, also giving you the chance to use high quality wire which will be useful. _\Hennessey|Venom| F5/___
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1450 ![]() ![]() ![]() |
Would have thought so ......... Do you have the other wires for the head unit ??? It is pretty simple to run new wires for the fronts anyways
![]() ![]() ![]() Click image to enlarge |
Okay, plot thickens - I can see that the front left and right "leave" the big black plug, but not sign of them by the wiper motor - I am just going to re-run a new wire, then as you say, I can put in better quality.
Now for the scary bit - cutting a hole in the trim ![]() |
If your not the only owner it may be possible that they were cut off.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40 ![]() ![]() |
As Steve said earlier, they are probably taped up somewhere out of sight. I found the passenger side ones easily enough but the driver's side were well hidden - It must have taken me almost an hour to find them
![]() ![]() I was initially worried about cutting the trim too, but if you follow Jim's advice in my thread you won't go far wrong ![]() |
Thanks for all the help - stereo now in and working fine - I did end up finding the drivers side speaker wire, but re-threaded a new wire for the passenger side
![]() Need to decide on the next project now ![]() ![]() Click image to enlarge |
Glad it's going well.
