Home > Td5 > Cruise control
landyman37
Cruise control
Hi I have fitted cruise control on our td5 defender which don't work Big Cry I have plugged the nanocom in checked through the system. It says the clutch switch is on unplugged the connector on the clutch pedal still on. Plugged back into the clutch switch checked continuity to earth with the clutch pressed found ok released pedal breaks the earth. So it looks like the system us working but why is the clutch switch on according to the nano.
It's a nnn ecu
Thanks phil
Post #274066 15th Oct 2013 7:05pm
landyman37
Anyone ?
Post #275961 23rd Oct 2013 5:59am
check the switch ?
check the cable ?
did you buy a kit or is it DIY ?
Post #275975 23rd Oct 2013 8:49am
landyman37
I have check the switch that looks all ok just a bit confusing how the clutch switch is active Even if you pull the wires off. Also tried bridging the wires together. I have also took the pin out of the ECU and it is still active.
It's a DIY kit
Phil
Post #275978 23rd Oct 2013 9:31am
I'm sure I've read somewhere (on here) that the way the Nanocom reads the clutch switch is backwards to the way that seems logical, i.e. it reads 'on' when the pedal is not being pressed and 'off' when it is, or something like that anyway. Darren
Post #275985 23rd Oct 2013 10:17am
hi/low certainly reads back to front on nano1
Post #276012 23rd Oct 2013 1:35pm
landyman37
Daren is that just on the defender td5 because I have tried it on my disco 2 and that reads the correct way round. Also when you press the clutch pedal nothing changes on the nanocom when connected to the defender Confused . What I could do with is someone out there with a td5 and a nanocom to plug there's in and read it out to see what it says.
Phil
Post #276020 23rd Oct 2013 2:16pm
Ah, sorry. I may have been getting mixed up with the hi/low switch that Jim has mentioned. Darren
Post #276243 24th Oct 2013 9:30am
landyman37
Can anyone with a nanocom and defender plug it in and see what the clutch switch reads.
Phil
Post #276715 25th Oct 2013 8:34pm
I'm away from my 110 this weekend but I can on Monday if nobody can do it earlier. Darren
Post #276718 25th Oct 2013 8:41pm
landyman37
Darren thanks mate
Phil
Post #276720 25th Oct 2013 8:46pm
landyman37
Any good with the info Darren
Phil
Post #278131 30th Oct 2013 9:39pm
