![]() | Home > Td5 > Cruise control |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 156 ![]() |
Anyone ?
check the switch ?
check the cable ? did you buy a kit or is it DIY ? |
I have check the switch that looks all ok just a bit confusing how the clutch switch is active Even if you pull the wires off. Also tried bridging the wires together. I have also took the pin out of the ECU and it is still active.
It's a DIY kit Phil |
I'm sure I've read somewhere (on here) that the way the Nanocom reads the clutch switch is backwards to the way that seems logical, i.e. it reads 'on' when the pedal is not being pressed and 'off' when it is, or something like that anyway. Darren
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
hi/low certainly reads back to front on nano1
Daren is that just on the defender td5 because I have tried it on my disco 2 and that reads the correct way round. Also when you press the clutch pedal nothing changes on the nanocom when connected to the defender
![]() Phil |
Ah, sorry. I may have been getting mixed up with the hi/low switch that Jim has mentioned. Darren
Can anyone with a nanocom and defender plug it in and see what the clutch switch reads.
Phil |
I'm away from my 110 this weekend but I can on Monday if nobody can do it earlier. Darren
Darren thanks mate
Phil |
Any good with the info Darren
Phil |
