Home > Maintenance & Modifications > Clonking whilst setting off in 1st gear
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
I have a clonking sound when setting off in 1st gear and can only think that its a prop shaft UJ. What are you guys thought?
Oh and its a 110 TD5
Post #273877 14th Oct 2013 10:16pm
landy andy
Uj,s on prop, rear axle ball joint, drive flanges, something loose.
Andy
Post #273888 14th Oct 2013 10:25pm
x-isle
Possibly the rear axle ball joint as suggested.
Cheap fix but can be a pain to remove the old joint from the fulcrum.
Mines on the "to get around to list".
Could also be rear shock bushes too. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #273915 14th Oct 2013 11:13pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Clonking whilst setting off in 1st gear
In my 110 td5 the clonk came from the flange and the rear left half shaft, I changed the rear shafts and all the flanges and the clomks was ..... rediced to a minimum Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #273924 15th Oct 2013 3:17am
