![]() | Home > Maintenance & Modifications > Clonking whilst setting off in 1st gear |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
I have a clonking sound when setting off in 1st gear and can only think that its a prop shaft UJ. What are you guys thought?
Oh and its a 110 TD5 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6051 ![]() ![]() |
Uj,s on prop, rear axle ball joint, drive flanges, something loose.
Andy |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Possibly the rear axle ball joint as suggested.
Cheap fix but can be a pain to remove the old joint from the fulcrum. Mines on the "to get around to list". Could also be rear shock bushes too. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
In my 110 td5 the clonk came from the flange and the rear left half shaft, I changed the rear shafts and all the flanges and the clomks was ..... rediced to a minimum Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
