![]() | Home > Technical > What thread |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Retracted due to new information below
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
16 X 1.5 according to the write up here:-
"We manufacture Wheel Nuts in Marine Grade 316 Stainless Steel (A4) They are suitable to fit to the Series 3 Landrover, the Landrover 90, Landrover 110, the Landrover Defender and Discovery and Range Rover which have Steel Type Wheels fitted to them and have wheel studs which are 16mm x 1.5." http://www.wrington.co.uk/landrover.htm If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
That's a standard M6 Fine thread.
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
It's definitely M16 x 1.5. Darren
| simon119 Member Since: 05 Apr 2012 Location: SG11, Herts Posts: 40
Have got spare wheel nuts your welcome to at work if you need them
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
Thanks but it's not nuts I require, it's bolts.
I've got a spare wheel carrier on the back of the double cab with studs, but they are a different thread, so my nuts won't fit. Only thing I can think of doing is replacing these studs with the correct threaded items. So next question who sells M16x1.5 bolts? Andy |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
They an an ISO metric Fine Series thread, whereas almost all other metric threads you'll come across are from the much more common ISO metric Coarse Series.
There is also an even less common Extra Fine Series. For an M16 thread, the pitches are as follows:- Coarse Series - 2.0mm Fine Series - 1.5mm Extra Fine Series - 1.0mm Taps, dies, studs, nuts, etc are all available from specialist suppliers. Google M16 x 1.5 bolt and you'll find many suppliers, they are actually not that unusual! |
Can't find anyone selling them though. Only need two bolts
Andy |
would 2 wheel studs and a welder do it??
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Cutwell is a great supplier of quality Machine tap and dies they always complain we dont spend enough our answer is their kit is good and it doesnt wear out
Have you tried C W Fasteners?
Or ebay? |
Yes that's another option. You got any? |
Will have a look tomorrow when im back in the warehouse and let you know
| v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195
i will also check at work, fasteners is our bussiness. what length is required? 110 xs s/wagon
s3 swb soft top |
