Home > Technical > What thread
landy andy
What thread
Any body know what thread wheel studs are?
Must be something imperial, or a bit different as I can't match it with anything that I've got
Andy
Post #271993 7th Oct 2013 10:38am
Retracted due to new information below
Post #271995 7th Oct 2013 10:46am
K9F
16 X 1.5 according to the write up here:-
"We manufacture Wheel Nuts in Marine Grade 316 Stainless Steel (A4)
They are suitable to fit to the Series 3 Landrover, the Landrover 90, Landrover 110, the Landrover Defender and Discovery and Range Rover which have Steel Type Wheels fitted to them and have wheel studs which are 16mm x 1.5."
http://www.wrington.co.uk/landrover.htm If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271997 7th Oct 2013 11:04am
Laurie
That's a standard M6 Fine thread.
Post #272001 7th Oct 2013 11:24am
It's definitely M16 x 1.5. Darren
Post #272003 7th Oct 2013 11:28am
simon119
United Kingdom 2000 Defender 90 Td5 HT Rutland Red
Have got spare wheel nuts your welcome to at work if you need them
Post #272007 7th Oct 2013 12:20pm
landy andy
Thanks but it's not nuts I require, it's bolts.
I've got a spare wheel carrier on the back of the double cab with studs, but they are a different thread, so my nuts won't fit. Only thing I can think of doing is replacing these studs with the correct threaded items.
So next question who sells M16x1.5 bolts?
Andy
Post #272011 7th Oct 2013 1:01pm
They an an ISO metric Fine Series thread, whereas almost all other metric threads you'll come across are from the much more common ISO metric Coarse Series.
There is also an even less common Extra Fine Series.
For an M16 thread, the pitches are as follows:-
Coarse Series - 2.0mm
Fine Series - 1.5mm
Extra Fine Series - 1.0mm
Taps, dies, studs, nuts, etc are all available from specialist suppliers. Google M16 x 1.5 bolt and you'll find many suppliers, they are actually not that unusual!
Post #272014 7th Oct 2013 1:13pm
landy andy
Can't find anyone selling them though. Only need two bolts Big Cry Big Cry Big Cry
Andy
Post #272016 7th Oct 2013 1:17pm
simon119
would 2 wheel studs and a welder do it??
Post #272020 7th Oct 2013 1:30pm
Cutwell is a great supplier of quality Machine tap and dies they always complain we dont spend enough our answer is their kit is good and it doesnt wear out Mr. Green
Post #272022 7th Oct 2013 1:39pm
Have you tried C W Fasteners?
Or ebay?
Post #272024 7th Oct 2013 1:55pm
landy andy
Yes that's another option. You got any?
Post #272043 7th Oct 2013 3:09pm
simon119
Will have a look tomorrow when im back in the warehouse and let you know
Post #272083 7th Oct 2013 6:20pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
i will also check at work, fasteners is our bussiness. what length is required? 110 xs s/wagon
s3 swb soft top
Post #272098 7th Oct 2013 7:16pm
