![]() | Home > Maintenance & Modifications > NAS step chequer plate replacement |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Looks good Rusty. Just one thing. As that is brand new shiny ally chequer plate did you etch primer it before painting it black?
The metal is so smooth you will find the paint just flakes off after a while. This is what I have used in the past, http://www.halfords.com/webapp/wcs/stores/...yId_165625 works a treat |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548
Thanks Geo. I haven't bothered with etch primer this time as I'll be repraying them all again next year. The paint seems pretty durable and I've not had any flaking as yet, just the odd scratch and wear mark on the cills from getting in and out of the landy. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
My rear tow step has a moulded rubber tread plate on it are they not all like this ? 2005 Td5 90 XS
Steve |
It depends on whom you buy your step from Lou. Genuine will have the rubber, but some copies have chequer plate or for less money, nothing...
Also the rubber on occasions does peel off... |
My rubber tread plate is held on with plastic nuts and bolts similar to number plate bolts and can be removed/replaced. I recently removed mine when i had the rear step powder coated.
I will now find myself looking at all rear towsteps to see what they have on them ! 2005 Td5 90 XS Steve |
Lou you know that's a short slippery slope to some interesting looks from passers-by...
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Does the NAS step have holes for tow ball or two inch receiver?
I like the idea of the two inch receiver hole that I have seen on some. Andy |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
The real NAS ones (fitted to NAS Defenders) have a 2" receiver.
The version available outside the US - the "rear step bumper", technically not an NAS step - has tow ball holes. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks, so I need an original NAS, or does anyone make a "true" NAS copy.
Protection and Performance might
2015 D90 XS SW |
It's not on their website, but will ask them.
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314
I be interested in one - could it be anodised though ? Cheers,
Superspoons |
I believe it can. Having had a quick read of this it seems that there is a DIY solution too but I'd be inclined to get it done professionally.
http://freepages.pavilion.net/nickfull/anodise.htm 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
| All times are GMT |
