Home > Maintenance & Modifications > Relocation of hand break lever
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Hi has anyone done this ?
And if so was it as easy as this shows ?
http://www.reedx.net/landrover/mods/handbrake/index.htm
Cheers It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #265930 12th Sep 2013 10:27am
Lou Sparts
As far as i know the Disco 1 handbrake is the same but more plentyfull.
The other option is to put the handbrake on the passenger side as in a LHD but not so user friendly. 2005 Td5 90 XS
Steve
Post #265934 12th Sep 2013 10:36am
yes, I've done it, makes a real difference Thumbs Up
I used a RRC hand brake but D1's also work
takes about 30 mins
Post #265935 12th Sep 2013 10:37am
mk1collector
Yes I've done it. It was quite simple but best to have two pairs of hands. I used a disco 1 lever.
Loads more comfortable on longer journeys and for the £15 or so for the lever and an hour or so work it's well worth it Thumbs Up
Ray
Post #265957 12th Sep 2013 11:42am
Merlin
I've now moved my hand brake, using a RR one that I bought off of flea bay for £15.00. I'm not happy with the RR gaiter as it looks a bit dated. Would prefer a black rexcine one. If you are going to do this, and I would recommend it, the forward bolt hole is 150mm from the front seat mounting bolt. If I was doing this again I would drill the first one another 20mm further back, as it just touches my leg. I used a 19mm drill for the cable hole, which came out as actually 22mm, which was fine. Here's some pictures before the cubby box was re-fitted. BTW getting the cubby box out took 3 hours, as the Rivnuts turned. The hand brake mod only took one hour:
The blanking plate was made from a spare single DIN blanking cover.
I'd recommend doing this mod, as now I have plenty of room to stretch my legs in the foot well.
Merlin
Post #270747 1st Oct 2013 6:51pm
mk1collector
You can re-use the gaiter off your original handbrake lever, it fits quite well Thumbs Up
Post #270750 1st Oct 2013 7:10pm
GUM97
I assume this has no adverse affects to the cable? eg. With it being further back (thus closer to the handbrake assembly itself), or does it work the same irrespective of positioning? An engine to TDi for!
Post #270753 1st Oct 2013 7:14pm
mk1collector
Works exactly the same, you just twist the cable a different way.
Post #270754 1st Oct 2013 7:17pm
jst
yep, done it, works well Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #270815 1st Oct 2013 9:25pm
sparkylee
Here's pic of the reused rubber gator
:thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
FFRR 4.2 vogue
Post #270844 1st Oct 2013 10:45pm
ZeDefender
I want to do this when I fit the X-Brake.
@ Sparky - is yours a LHD or have you stuck it next to the passenger's leg?
Did you use the original Defender lever?
Matt Tell someone you love them today because life is short.
Post #270846 1st Oct 2013 10:50pm
sparkylee
No it's not LHD just I'm a big lad and it gave me a bit extra space
If you look under
The best £5 I've spent posts
There's more pics It's good to be back from the dark side
FFRR 4.2 vogue
Post #270849 1st Oct 2013 11:03pm
ZeDefender
*Edit* Just found the other thread Embarassed
http://www.defender2.net/forum/topic23266.html
Thumbs Up Tell someone you love them today because life is short.
Post #270850 1st Oct 2013 11:06pm
ZeDefender
... do you now know what lever you used? Yours looks much better/OEM than the RR one in the how-to...
*Edit* okay - looks like Disco 1, like mk1collector.
Post #270852 1st Oct 2013 11:13pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
This is my upgrade. I kept the lever further forward than others because there wasn't a lot of room between the cubby box and seat.
http://defender90xs.blogspot.com/2013/09/r...lever.html
I hope it is of some use.
Post #270885 2nd Oct 2013 8:37am
