![]() | Home > Maintenance & Modifications > What to use to stick down carpets |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20945 ![]() ![]() |
Depends if you want it to be permanent or removable? If removable and you want to remove it often then I would go for adhesive velcro.
If permanent I would go for this: http://www.ebay.co.uk/itm/Stikatak-Supersp...2c4d1cb0b2 ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Cheers Steve - It'll be permanent so I'm thinking a strong tape of some sort. When I stripped the 50th there were strips of tape holder the carpet to the seat boxes/floor. Cheers,
Superspoons |
It's up to you really. The spray glue gives a better over all adhesion though. ____\We|Will|Win/___
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I would use aerosol upholstery adhesive simply spray the area to be covered and the carpet wait a couple of minutes and position the trim where you want it.
Can probably get it on the bay. Have used this on RRC headlinings with great results. Hope this helps ![]() Steve |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
I used this for stickin 1.5mm thick rubber sheet to the sides and roof of my Defender.
http://www.ebay.co.uk/itm/1-litre-Brushabl...2a2dfc97a3 |
