Home > Maintenance & Modifications > What to use to stick down carpets
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Hi,
I'm currently recommissioning a Defender 50th. I need some advice on what to use to stick down the interior carpets over the rear tub.
Any products to recommend? I'm thinking double side tape?? Cheers,
Superspoons
Post #262291 29th Aug 2013 10:26pm
Depends if you want it to be permanent or removable? If removable and you want to remove it often then I would go for adhesive velcro.
If permanent I would go for this: http://www.ebay.co.uk/itm/Stikatak-Supersp...2c4d1cb0b2
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #262292 29th Aug 2013 10:29pm
superspoons
Cheers Steve - It'll be permanent so I'm thinking a strong tape of some sort. When I stripped the 50th there were strips of tape holder the carpet to the seat boxes/floor. Cheers,
Superspoons
Post #262293 29th Aug 2013 10:32pm
It's up to you really. The spray glue gives a better over all adhesion though. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #262294 29th Aug 2013 10:34pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I would use aerosol upholstery adhesive simply spray the area to be covered and the carpet wait a couple of minutes and position the trim where you want it.
Can probably get it on the bay.
Have used this on RRC headlinings with great results.
Hope this helps Thumbs Up . 2005 Td5 90 XS
Steve
Post #262295 29th Aug 2013 10:35pm
jimbob7
I used this for stickin 1.5mm thick rubber sheet to the sides and roof of my Defender.
http://www.ebay.co.uk/itm/1-litre-Brushabl...2a2dfc97a3
Post #262320 30th Aug 2013 12:09am
