![]() | Home > Technical > Wet Clutch pedal |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
That will be the clutch cylinder. Best to change both, slave and master, as they have both done the same amount of work. The fluid will be brake fluid, so be cautious where it ends up
Andy Last edited by landy andy on 28th Aug 2013 9:06pm. Edited 1 time in total |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6042
Knackered clutch master cylinder prehaps? 1999 Defender TD5 110
| ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277
ive been told its Dot 4 dripping there which is not good on paint work...
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Yep, clutch master cylinder seals knackered. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
So am i right in saying this can be replaced (the seal) instead of the whole master cylinder.
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
For the faff factor alone I would just change the master cylinder for a good quality one.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
You can indeed replace just the seal but its a false economy as the bore of the cylinder will be worn causing the new seal to wear rapidly.
Do it right do it once. Steve |
Thanks chaps,
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
From Paddocks
http://www.paddockspares.com/catalogsearch...ehicle=122 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Best replace the slave cylinder at the same time. Steve.
