![]() | Home > Technical > Wet Clutch pedal |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5980 ![]() ![]() |
That will be the clutch cylinder. Best to change both, slave and master, as they have both done the same amount of work. The fluid will be brake fluid, so be cautious where it ends up
Andy Last edited by landy andy on 28th Aug 2013 9:06pm. Edited 1 time in total |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
Knackered clutch master cylinder prehaps? 1999 Defender TD5 110
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
ive been told its Dot 4 dripping there which is not good on paint work...
Yep, clutch master cylinder seals knackered. Steve.
So am i right in saying this can be replaced (the seal) instead of the whole master cylinder.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
For the faff factor alone I would just change the master cylinder for a good quality one.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
You can indeed replace just the seal but its a false economy as the bore of the cylinder will be worn causing the new seal to wear rapidly.
Do it right do it once. ![]() Steve |
Thanks chaps,
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
From Paddocks
http://www.paddockspares.com/catalogsearch...ehicle=122 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Best replace the slave cylinder at the same time. Steve.
