Home > Maintenance & Modifications > Sealing seatboxes
Sealing seatboxes
Who has silicone sealed their seatboxes from inside? I find in the winter a lot of moisture and a little bit of dirt / dirty water. This shouldn't be I know which obviously means water is getting in. If I seal them well is there likely to be bad condensation occur instead and keep it moist then too?
Confused ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #261009 24th Aug 2013 4:40pm
df1
I've tried both sealing and vented but seem to get condensation either way.
I got one of the under cubby electrical boxes from gmb Germany and am just putting the finishing touches to moving ecu, relays and fuses from the seat box.
I think it's the surest way to keep these electrics dry and safe.
Post #261016 24th Aug 2013 5:38pm
I sealed my seat boxes before my arctic trip, I was concerned about battery temperatures and the gel freezing, once done , no problem with water, ice etc
I also put a few silicone anti moisture bags in there ...
I can't understand why they are such a bad fit, the std battery has a breather pipe so no real need for gaps
Post #261085 25th Aug 2013 6:23am
I was thinking of something along those lines too. Funny you should mention that. ____\We|Will|Win/___
Post #261141 25th Aug 2013 10:09am
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
I was thinking of that for the cabin, let alone the battery box Whistle My Disco 'best bits'
Defender 110 XS CSW 2013
Post #261169 25th Aug 2013 1:29pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I use these in all our vehicles to keep them dry inside. Work a treat and re-usable.
http://www.amazon.co.uk/s?ie=UTF8&fiel...ch-type=ss Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #261176 25th Aug 2013 2:52pm
DiscoStu
Thumbs Up
Didn't know they existed Laughing My Disco 'best bits'
Post #261179 25th Aug 2013 3:09pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Just brainstorm but what about fitting a pc-ventilator in the lid? Wouldn't that do the trick to solve the condensation problem? Of course after sealing the box.
Power for it is close by and I don't think they consume much power.
Only downside is ofcourse it's not a mechanical mod, but most of us have an old pc laying around, so should be cheap.
I think "in lid" becouse in the side reduces wading depth. It should blow outwards of course.
Post #261181 25th Aug 2013 3:24pm
Good idea zone30 but I took my defender to the arctic in February this year after sealing it and it was fine and still is, the silicone packs work well and don't consume any electricity
I like the packs on amazon Thumbs Up
Post #261200 25th Aug 2013 4:44pm
Litch
I use something similar in my wife's Freelander.
In the winter the build up of condensation when parked up was a rear pain and took some time of de-misting before it was clear to drive (start wiping the windows and you had to finish the job to avoid smears so it was easier to leave them to de-mist naturally). When it was really cold it was worse because the condensation froze on the inside which meant you had to melt it before drying it off. Bought some silica-gel bags from Ebay (4 x 500G) and hey-presto, no more condensation whatever the conditions.
I use two bags at a time and leave the other two in the house to dry out and be ready for re-use. I find that normally I have to rotate them every couple of weeks. In the vehicle I leave one under the passenger seat or in the door-pocket and one in the tray on the dash. The effect really is remarkable and I have no hesitation on recomending them to anyone. Very Happy ONE LIFE, GET IT!
Post #261445 26th Aug 2013 7:24pm
Some excellent ideas here chaps. Thumbs Up ____\We|Will|Win/___
Post #261466 26th Aug 2013 8:05pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Bpman did you also seal the battery drain holes with tape or the plastic lugs you can get for the front floor mats? 2004 TD5 Defender 90 xs station wagon
Post #262450 30th Aug 2013 6:22pm
