![]() | Home > Maintenance & Modifications > Sealing seatboxes |
| df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
I've tried both sealing and vented but seem to get condensation either way.
I got one of the under cubby electrical boxes from gmb Germany and am just putting the finishing touches to moving ecu, relays and fuses from the seat box. I think it's the surest way to keep these electrics dry and safe. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I sealed my seat boxes before my arctic trip, I was concerned about battery temperatures and the gel freezing, once done , no problem with water, ice etc
I also put a few silicone anti moisture bags in there ... I can't understand why they are such a bad fit, the std battery has a breather pipe so no real need for gaps |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
I was thinking of something along those lines too. Funny you should mention that. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255
I was thinking of that for the cabin, let alone the battery box
Defender 110 XS CSW 2013 Last edited by DiscoStu on 25th Aug 2013 3:08pm. Edited 1 time in total |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
I use these in all our vehicles to keep them dry inside. Work a treat and re-usable.
http://www.amazon.co.uk/s?ie=UTF8&fiel...ch-type=ss
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Didn't know they existed Defender 110 XS CSW 2013 |
| zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669
Just brainstorm but what about fitting a pc-ventilator in the lid? Wouldn't that do the trick to solve the condensation problem? Of course after sealing the box.
Power for it is close by and I don't think they consume much power. Only downside is ofcourse it's not a mechanical mod, but most of us have an old pc laying around, so should be cheap. I think "in lid" becouse in the side reduces wading depth. It should blow outwards of course. |
Good idea zone30 but I took my defender to the arctic in February this year after sealing it and it was fine and still is, the silicone packs work well and don't consume any electricity
I like the packs on amazon |
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
I use something similar in my wife's Freelander. In the winter the build up of condensation when parked up was a rear pain and took some time of de-misting before it was clear to drive (start wiping the windows and you had to finish the job to avoid smears so it was easier to leave them to de-mist naturally). When it was really cold it was worse because the condensation froze on the inside which meant you had to melt it before drying it off. Bought some silica-gel bags from Ebay (4 x 500G) and hey-presto, no more condensation whatever the conditions. I use two bags at a time and leave the other two in the house to dry out and be ready for re-use. I find that normally I have to rotate them every couple of weeks. In the vehicle I leave one under the passenger seat or in the door-pocket and one in the tray on the dash. The effect really is remarkable and I have no hesitation on recomending them to anyone. |
Some excellent ideas here chaps.
| johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459
Bpman did you also seal the battery drain holes with tape or the plastic lugs you can get for the front floor mats? 2004 TD5 Defender 90 xs station wagon
| All times are GMT |
