![]() | Home > Technical > Electric Window Problem - or just OCD... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
That's what my passenger one does, tried fiddling with it, it made it worse, so put it back as it was. It's all to do with the mechanism. Personally I'd say don't worry leave it alone.
Andy |
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 ![]() ![]() |
Thanks Andy - now I know it's not just me I can leave well alone
![]() Cheers 2011 Defender 90 SW 2006 Discovery 3 HSE |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Try lubing the window tracks with silicon spray, GT85,Mr Sheen,etc. Don't use WD40 it's harmful to certain rubbers and collects dirt.
Thanks jimbob7
Don't need to remove door cards,open window and spray lube down the glass tracks.
Ah OK, thanks - top tip
![]() 2006 Discovery 3 HSE |
@ jimbob7. Just sprayed a little bit of ACF50 in the tracks after checking it was rubber safe. Window glides up and down nice and smoothly now
![]() Thanks for the simple tip ![]() 2006 Discovery 3 HSE |
