Home > Maintenance & Modifications > Entreq front mudflap extensions
ericvv
Have received from Brendan a set of these, the black powder coated version. Typical Entreq quality, just want to mention that in several older threads on this subject it was always stated that you need a 9mm drill to remove the 6mm rivets of the original set-up. I used just a 6.5mm drill bit for this, and careful drilling away the rivet until the support starts to spin works very well, and leaves the original holes in the rubber mudflap entirely intact.
Here are some before 'n after pictures.
Before...
Process...
A. Old mudflap removed with 8mm spanner. Shows that the Dinitrol boys were very thorough as the mudflaps had been removed prior to Dinitrol treatment as it should be done. Thumbs Up
B. The full Entreq kit. (Note: Does not include the Classic Land Rover magazine Wink )
C. Old rivets drilled out without damaging the flaps.
D. Mudflap washed up and installed in the Entreq holder
E. Installation completed with 10mm spanner, and using lots of anti-corrosion paste in the chassis holes
After...
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #258402 13th Aug 2013 1:06pm
MartinK
Excellent write-up - thanks for taking the time to do it Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #258526 14th Aug 2013 6:30am
