![]() | Home > Maintenance & Modifications > Entreq front mudflap extensions |
Have received from Brendan a set of these, the black powder coated version. Typical Entreq quality, just want to mention that in several older threads on this subject it was always stated that you need a 9mm drill to remove the 6mm rivets of the original set-up. I used just a 6.5mm drill bit for this, and careful drilling away the rivet until the support starts to spin works very well, and leaves the original holes in the rubber mudflap entirely intact.
Here are some before 'n after pictures. Before... ![]() Click image to enlarge Process... A. Old mudflap removed with 8mm spanner. Shows that the Dinitrol boys were very thorough as the mudflaps had been removed prior to Dinitrol treatment as it should be done. ![]() ![]() Click image to enlarge B. The full Entreq kit. (Note: Does not include the Classic Land Rover magazine ![]() ![]() Click image to enlarge C. Old rivets drilled out without damaging the flaps. ![]() Click image to enlarge D. Mudflap washed up and installed in the Entreq holder ![]() Click image to enlarge ![]() Click image to enlarge E. Installation completed with 10mm spanner, and using lots of anti-corrosion paste in the chassis holes ![]() Click image to enlarge After... ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
Excellent write-up - thanks for taking the time to do it
