![]() | Home > Technical > EGR Cooler leaking |
BAS Remap for exclude electronically the EGR and than remove the cooler Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Spikey Member Since: 02 Aug 2013 Location: paterson Posts: 6 ![]() ![]() ![]() |
Thanks dgardel.
I have removed the cooler. Would this cause loss of coolant out the exhaust? |
Yes, if the heat exchange pack is broken, the coolant go trought the gas (both to the inlet manifold and to the axhaust) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Cool Thanks dgardel
