Home > Technical > EGR Cooler leaking
Spikey
South Africa 2008 Defender 110 Puma 2.2 PU Keswick Green
EGR Cooler leaking
After a frustrating 2 hour internet search I have eventually discovered the name of the EGR Cooler.
My PUMA is over heating and loosing power
Engine coolant level is dropping at approximately 5 liters every 10 km
Excessive water was being emitted from the exhaust
After an extensive search, by my mechanic, he found a tiny pin prick leak in the 'ERG Cooler' on the side with the multiple small holes.
Could this be the reason for coolant loss out the exhaust?
Some rapid assistance would be greatly appreciated!
PS I cant figure out how to post an image on this forum.
[/img]
Post #256788 6th Aug 2013 7:30pm
dgardel
Italy
BAS Remap for exclude electronically the EGR and than remove the cooler Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #256813 6th Aug 2013 8:11pm
Spikey
Thanks dgardel.
I have removed the cooler.
Would this cause loss of coolant out the exhaust?
Post #256924 7th Aug 2013 9:16am
dgardel
Italy
Spikey wrote:
Thanks dgardel.
Yes, if the heat exchange pack is broken, the coolant go trought the gas (both to the inlet manifold and to the axhaust) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #256934 7th Aug 2013 10:17am
Spikey
Cool Thanks dgardel Thumbs Up
Post #257846 11th Aug 2013 7:43am
