Home > Technical > aframe joint
stevetd5
Australia 2002 Defender 110 Td5 SW Alpine White
aframe joint
Hi, I need to replace the a frame ball joint wondering which way to go, Oe replacement, or one of the adjustable type? I will be replacing bushes also while I'm at it. Any suggestions, thanks
Post #256674 6th Aug 2013 11:45am
WarPig
Have a look at the Gwyn Lewis website as they sell one that can be adjusted-lubricated (can't remember which).
http://www.gwynlewis4x4.co.uk/
Post #256697 6th Aug 2013 1:43pm
jst
its a wide angle one too for lifts/droop changes etc from Gwyn
do you have a press?
if not it can be simpler to buy the whole thing in the holder, although obviously more expensive.
if you have std suspension then a std one will work well. i use bearmach. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256724 6th Aug 2013 3:44pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I used a standard delphi one.
Adjustable ones are often not, after a few years of crud, salt and rust!
as for installing/removing, it seems to be pot luck - mine came out with a deft whack with a lump hammer.
Post #256746 6th Aug 2013 4:33pm
Litch
My Bearmach adjustable one has been in for over 10-years and I have only had to adjust it once.
I fitted it without having to resort to a press and then coated it liberally with Waxoyl, when I adjusted it earlier this year it was clean & corrosion free underneath the Waxoyl.
When the time comes to replace it I will fit the same item. ONE LIFE, GET IT!
Post #256809 6th Aug 2013 8:08pm
stevetd5
Thanks all I will probably go adjustable, more likely to wear (corrugations) than rust here in Aust.
Post #256941 7th Aug 2013 10:31am
Martin
Site Admin
Buy the whole thing in the holder (fulcrum).
Pretty certain Simon @ MPS will be able to supply it, and there's an OEM version too Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #256981 7th Aug 2013 12:32pm
