![]() | Home > Technical > Snorkel Theory. |
| DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167
No disrespect intended Phil but are you still taking your medication!!
With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
This is the result of too many sleepless nights due to the minilandyphill
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Ha, nice - I did exact the same calculations some years ago to calculate air speed and resistance in the snorkel.
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
So you need a snorkel and a diagnostic to proc this theory come on D2. I have pondered tge snorkel in much the same way and have Hunted in depth testing. Your intelligent rant ha. Proven a theory shame I have neither diagnostic kit or a snorkel
| RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596
BAS has done some snorkel testing. There's a thread on it somewhere. Think that would answer your question.
He was testing with and without snorkel on his rolling road. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
interesting points and intrigued to see what falls out of this.
on another note though, Ram air, from my biking days and SRAM i was led to believe there was a benefit of it when you were about 90mph? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Landyphil Member Since: 23 Jul 2012 Location: Lake District Posts: 87
No sleep issues so far John........he's rarely grumpy but always hungry!
It's interesting to hear that BAS looked at this but it wouldn't be so much a rolling road more a windtunnel or at least a rolling road with an accurate blown air supply attached to the snorkel to simulate the airspeed. As for Ram Air this is really the crux of it. Obviously you can't pressurise (above an arbitary amount) intake air through an air scoop or ram at any speed below I think 1/3 of the speed of sound but that doesn't mean you can't reduce the inlet vaccum by providing more air at atmospheric pressure than the engine needs. Which will give a little benefit. Question is how much? To do a basic experiment I suppose you could just mod the side grill and make a scoop to fit there although at such close quarters to the wing and arch you'd get some odd aero effects no doubt. I have no genuine use for a Snorkel on the Puma and idea of modifying a Defender (especially spending money) purely for looks is something that's never going to happen so am wary of spunking about £200, in the case of a gen Safari snorkel on this theory. But if it did prove slightly beneficial then in the very long term it would be worth it as I'm not planning to get rid of any of the landy's any decade soon. After all even 0.25mpg would make back £200 over 100,000 miles. 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
| SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388
Interesting analysis. I'm not a mech eng but your analysis really works on averages - average speed, average air flow, total displacement etc. The demand for air from each cylinder is peaky as the valve opens and air is sucked in (or pushed in). So I'm thinking there are peaks of pressure (no cyclinders demanding air) and then peaks of vacuum or near atmospheric when the pistons are sucking. My guess would be that these pulses of air demand are sinusoidal as each cylinder moves from TDC to BDC.
So my thinking is that the DYNAMIC demand is far higher than the displacement figures suggest. However, when you consider the turbo is spinning and serves all the cylinders in an average way then this would suggest an averaging effect driven by turbo pressure feeding the demand, the pressured air downstream of the turbo releasing its pressure from manifold when the inlet valve opens into the expanding cylinder Anyone out there who knows what they're talking about rather than my BS Post note: anecdotally at motorway speeds it seems to make sod all difference whether the snorkel faces forwards or backwards. Where's Pete when you need him |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Simply
- more pipe line length = more losses due to air friction - air friction is (fluid speed)^2 dependent (double your speed = 4 time more frictions losses) = snorkel is losses from a fluid dynamics point of view. But should be necessary (dust and/or wading)
IID Pro MV License |
could there be that pressure builds up around the entrance to the snorkel too, what size does the snorkel need to be to actually take in the right amount of air at speed. if wind hits the entrance at 60 mph is the pressure on the rim the partially blocks the entrance there fore decreases its size ? all performance cars with cold air pipe work have massive intakes im sure the snorkel would need to be larger, given also that its not get directly forced air its getting disrupted air from the bungalow-like front of the defender. immediately the air is subject to friction in the pipe work with twists and bends too. performance cars again to increase efficiency in induction they have minimal bends as the also do in exhaust,. (which is the beauty of a defender exhaust pretty much a straight pipe )
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Here's a fact for you (probably)... 97.5% of snorkels are fitted for looks.
| abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79
My TD5 came with a snorkel, and the anti stall didn't work. I un-plumbed it and the anti stall works and there is more low down power.
| landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
which is pretty strange. For this moment I doubt there´s been a causality. Take a look at the "cfm" figures he wrote down. Revs near idle do not need that much air. A resistance (as what we can see the snorkel naughtily) has to do something with flow. The more flow needed the more the resistance shows an effect. It´s like you could easily breath through a drinking straw while reading this thread without stalling. But if you hurry up the stairs you will stall |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've fitted a snorkel to my TD5 and the anti-stall works exactly the same as it did before
