![]() | Home > Maintenance & Modifications > 1500 km after Allisport intercooler and BAS Remap |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
Hi there!
After running 1,500 km (1,000 km on highways) here is a report of the changes noticed in the Defender compared with a standard one: 1.- Easy to reach speed. Before, to overtaken other ca,r the Defender took more time than usual as a very heavy vehicle that struggle to pass from 60 kph to 120 KPH. With the new configuration, the change from 60 to 120 is more agile and the engine doenst looks forced: like a normal car. 2.- Less forced engine: At cruising speed of 120 KPH the engine sound more relaxed and quiet eliminating the typical trembles that you can feel at high speeds. Also this behavior disapearing during the acceleration process. 3.- Less noisy motor: The noise at the cabin has been reduced in special during the acelerations. 4.- Similar Fuel consumptions: not sensible variation in the fuel consumption. Cheers!! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Yep, sounds just like mine, also on Allisport intercooler and BAS v2 remap.
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
bravo Edo! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| All times are GMT |
