Home > Maintenance & Modifications > 1500 km after Allisport intercooler and BAS Remap
Eduardo
Hi there!
After running 1,500 km (1,000 km on highways) here is a report of the changes noticed in the Defender compared with a standard one:
1.- Easy to reach speed. Before, to overtaken other ca,r the Defender took more time than usual as a very heavy vehicle that struggle to pass from 60 kph to 120 KPH. With the new configuration, the change from 60 to 120 is more agile and the engine doenst looks forced: like a normal car.
2.- Less forced engine: At cruising speed of 120 KPH the engine sound more relaxed and quiet eliminating the typical trembles that you can feel at high speeds. Also this behavior disapearing during the acceleration process.
3.- Less noisy motor: The noise at the cabin has been reduced in special during the acelerations.
4.- Similar Fuel consumptions: not sensible variation in the fuel consumption.
Cheers!! Eduardo
Post #253539 24th Jul 2013 8:42pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Hi Eduardo sounds like good news, I'm thinking of a stage one re map myself with a similar increase in performance as your own.
Good Stuff
Regards Dave I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #253559 24th Jul 2013 9:33pm
Naks
Yep, sounds just like mine, also on Allisport intercooler and BAS v2 remap. Thumbs Up --
Post #253623 25th Jul 2013 10:28am
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
bravo Edo! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #253634 25th Jul 2013 11:59am
