Home > Wheels & Tyres > Checked your tyre pressures recently?
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
I have a 2011 2.4 Puma XS 90 with 18 inch Silverline wheels running 285/60 TR18 Cooper tyres.
I only ever use this on the road.
I have been running at 40p.s.i. with no apparent issues for the last 18 months. tread wear appears to be even and apart from the ride being a bit crashy on bumpy roads all is good. I average over 35 m.p.g. with this setup.
just been to my local garage to check the tyre pressures (first time in a few months) and the first one showed 50p.s.i.
I let some (an awful lot) of the air out to try to get back to 40p.s.i. but the gauge on the airline seemed a little inconsistent.
bought a digital tyre gauge (Ring @ £12.50) and the pressure is indeed 50p.s.i.
does the hot weather really make that much difference?
just been on Wikipedia to remind myself of my o level physics and found Gay-Lussac's law which states
P1/T1 = P2/T2 where P is pressure and T is temperature.
by my maths that means that P2 = P1*T2/T1 and when I put some numbers in 40psi*30°C/22°C = 55p.s.i.
put another way 40p.s.i.*23°C/22°C = 41.8p.s.i. i.e. for each °C rise in temperature the pressure rises by 1.8p.s.i.
this all assumes that the tyre has not expanded, which it clearly will have but that probably explains why the pressure is 50p.s.i. and not the calculated 55p.s.i.
thoughts please.
Post #252397 19th Jul 2013 12:28pm
Martin
Site Admin
You need to convert the temperatures to Kelvin rather than use deg C. To do that, add 273 to the deg C value.
So P2 = P1 * T2/T1 = 40 * (273+30)/(273+22) = 40 * 303/295 = 41 psi (2 sf)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #252400 19th Jul 2013 12:41pm
Martin
Site Admin
Also, the tyre (and its air) may be warmer than the surrounding air, which is measured in the shade.
A tyre in the sun will be hotter than that Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #252402 19th Jul 2013 12:43pm
theorangebandit
heat makes a huge difference to all working components on vehicles. I check my tyres weekly but I rack up plenty of miles.
easiest way to watch the pressures is check them on weather changes, drastic ones I mean, like snow then heat, then rain, then warm, and soo on
this will give you, in England about 3 weeks between checks lol
Post #252419 19th Jul 2013 2:19pm
shaun.mobile
Thanks for the reminder Martin, I had forgotten all about absolute zero.
Doesn't help explain the 50p.s.i. Though Confused Confused Confused
Post #252513 19th Jul 2013 11:48pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
And you dont get time to drive it if your in Scotland, too busy checking the tyres Rolling with laughter William
Post #252603 20th Jul 2013 4:35pm
