![]() | Home > Wheels & Tyres > Checked your tyre pressures recently? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
You need to convert the temperatures to Kelvin rather than use deg C. To do that, add 273 to the deg C value.
So P2 = P1 * T2/T1 = 40 * (273+30)/(273+22) = 40 * 303/295 = 41 psi (2 sf) ![]() ![]() |
Also, the tyre (and its air) may be warmer than the surrounding air, which is measured in the shade.
A tyre in the sun will be hotter than that ![]() ![]() ![]() |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
heat makes a huge difference to all working components on vehicles. I check my tyres weekly but I rack up plenty of miles.
easiest way to watch the pressures is check them on weather changes, drastic ones I mean, like snow then heat, then rain, then warm, and soo on this will give you, in England about 3 weeks between checks lol |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
Thanks for the reminder Martin, I had forgotten all about absolute zero.
Doesn't help explain the 50p.s.i. Though ![]() ![]() ![]() |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
And you dont get time to drive it if your in Scotland, too busy checking the tyres ![]() |
