Home > Technical > Wheel offset and bearing durability
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hello everybody,
I'm running since March a set of steel "modular" wheels, in the 7x16 variety, which I assume have a 8mm offset. Prior to that, my defender had the original Rostyle rims.
Some pros came with them, like better cornering and side slop stability, as well as some minus, like worse steering self centering and feedback.
But my question here is the following: will the wider stance of the new wheels, with the tyre further away from the hub center, reduce bearing life? will this also apply to other bearings, like swivels?
Thanks
Post #250559 10th Jul 2013 7:56pm
camelman
Hi there,
I've been running 16x8 mach5s with a 0 offset (i.e. 33 mm wider than standard) and have clocked up 100k miles without any issues.
Post #250601 10th Jul 2013 10:00pm
gbmud
2005 Defender 110 Td5 HT Belize Green
Landrover wheel bearings are very big relative to the size and weight of the car and rarely go wrong other than from failing oil seals and thus contamination or from lack of lubrication. Running a rim with less (more) offset will reduce bearing life but due to the bearings being so over specified will not decrease bearing life to the point of being inconvenient. IMHO.
Chris
Post #250674 11th Jul 2013 8:32am
Arierep
What about swivel bearings?
Post #250820 11th Jul 2013 10:50pm
camelman
No problems there either (yet Laughing )
Post #250847 12th Jul 2013 7:26am
Your wheelbearings and swivels are designed with sufficient strength to allow a fully laden vehicle to be driven in Camel Trophy style over Camel trophy terrain.
The additional load resulting from moving the wheels 30mm further outwards will be utterly negligible and well within design parameters and safetly margins.
Post #250854 12th Jul 2013 8:27am
