![]() | Home > Technical > Wheel offset and bearing durability |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Hi there,
I've been running 16x8 mach5s with a 0 offset (i.e. 33 mm wider than standard) and have clocked up 100k miles without any issues. ![]() |
gbmud Member Since: 02 Jun 2013 Location: Sussex, UK Posts: 167 ![]() ![]() |
Landrover wheel bearings are very big relative to the size and weight of the car and rarely go wrong other than from failing oil seals and thus contamination or from lack of lubrication. Running a rim with less (more) offset will reduce bearing life but due to the bearings being so over specified will not decrease bearing life to the point of being inconvenient. IMHO.
Chris |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 ![]() ![]() ![]() |
What about swivel bearings?
No problems there either (yet
Your wheelbearings and swivels are designed with sufficient strength to allow a fully laden vehicle to be driven in Camel Trophy style over Camel trophy terrain.
The additional load resulting from moving the wheels 30mm further outwards will be utterly negligible and well within design parameters and safetly margins. |
