![]() | Home > Maintenance & Modifications > Removing OE arch studs - pulling teeth or minor surgery? |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
You have to push the pin through the middle first, then removing them is easy.
Putting them back in again is a another matter though... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
Push / pull the centre pin back out (push from the back to the front) this will the release them properly. The centre pin expands the clip to the rear holding it in place. A small screwdriver should do it. As I said looking at it the centre pin needs to come towards you and be pushed forwards from the rear.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Thanks
| Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267
I took mine off last week. Just tapped the centres straight through with a punch. Nail would also work. I bought a packet of replacements of the web for £8 although I could have reused a fair amount of the originals as they were not damaged on removal.
Once the centre is punched through they pull out pretty easily. |
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
Lucky you |
Did you you use metal nuts & bolts or number plate type ones? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
I normally make the assumption that everything wil be a nightmare to take off. This time though I got lucky
I used some stainless bolts & nuts. |
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
Just done mine again, for bulkhead galvanising this time.
No reason why you shouldn't be able to re-use 90% of the old rivets, it is just a case of spotting the pins as you push them out. That said, I bought some spares before I started (no point having to leave the job half-done while waiting for parts to arrive) as they are only about 10P each. The only place I coulnd't re-use a rivet and went for SS nut & bolt instead was where I had to fit the rivet through the platsic arch, metal inner wheelarch and Gywn Lewis mud shild. It wouldn't have that so I bolted instead (luckily access to the rear isn't an issue at that point). ONE LIFE, GET IT! |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18048
In an emergency if you lose a pin you can make a replacement from a wire coat-hanger or an offcut of fence wire.
I'll let you guess how I know this! |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Ha ha good old fence wire, should be in every Defender owners toolkit along with some bailer twine. 2005 Td5 90 XS
Steve |
| All times are GMT |
