Home > Maintenance & Modifications > Removing OE arch studs - pulling teeth or minor surgery?
BigWheels
Are they extractable with a pair of pincers, or would I risk damaging the arches/enlarging holes doing that?
Otherwise its the knife! Shocked Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #249705 7th Jul 2013 11:32am
You have to push the pin through the middle first, then removing them is easy.
Putting them back in again is a another matter though... Darren
Post #249710 7th Jul 2013 11:48am
Push / pull the centre pin back out (push from the back to the front) this will the release them properly. The centre pin expands the clip to the rear holding it in place. A small screwdriver should do it. As I said looking at it the centre pin needs to come towards you and be pushed forwards from the rear.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #249711 7th Jul 2013 11:48am
BigWheels
Thanks Thumbs Up I'd buy another set for refitting. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #249713 7th Jul 2013 11:53am
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
I took mine off last week. Just tapped the centres straight through with a punch. Nail would also work. I bought a packet of replacements of the web for £8 although I could have reused a fair amount of the originals as they were not damaged on removal.
Once the centre is punched through they pull out pretty easily.
Post #249714 7th Jul 2013 12:04pm
WarPig
Lucky you Thumbs Up I would normally advise buying plenty of replacements as they can damage easily. In fact I ended up bolting my arches back on instead, as I found the plastic studs/rivets a complete pain in the arse Evil or Very Mad
Post #249740 7th Jul 2013 2:37pm
BigWheels
Did you you use metal nuts & bolts or number plate type ones? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #249749 7th Jul 2013 3:47pm
Bev
I normally make the assumption that everything wil be a nightmare to take off. This time though I got lucky Very Happy
Post #249751 7th Jul 2013 3:56pm
WarPig
I used some stainless bolts & nuts.
Post #249772 7th Jul 2013 5:57pm
Litch
Just done mine again, for bulkhead galvanising this time.
No reason why you shouldn't be able to re-use 90% of the old rivets, it is just a case of spotting the pins as you push them out. That said, I bought some spares before I started (no point having to leave the job half-done while waiting for parts to arrive) as they are only about 10P each.
The only place I coulnd't re-use a rivet and went for SS nut & bolt instead was where I had to fit the rivet through the platsic arch, metal inner wheelarch and Gywn Lewis mud shild. It wouldn't have that so I bolted instead (luckily access to the rear isn't an issue at that point). ONE LIFE, GET IT!
Post #250597 10th Jul 2013 9:52pm
In an emergency if you lose a pin you can make a replacement from a wire coat-hanger or an offcut of fence wire.
I'll let you guess how I know this!
Post #250696 11th Jul 2013 9:38am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Ha ha good old fence wire, should be in every Defender owners toolkit along with some bailer twine. 2005 Td5 90 XS
Steve
Post #250718 11th Jul 2013 11:10am
