Home > Maintenance & Modifications > Solar pannel
Page 2 of 2 <12
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
x-isle wrote:
I always planned to have 2 so the controller I fitted is 25amp.
Thumbs Up sorted then
I always thought it was such a waste of free power when my caravan was stood in the yard at home and the on board batteries are full up so I've fitted a set of leads from the batteries to an Anderson plug outside the van so I can plug jump leads in etc to charge additional batteries or power anything else you might have! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #252140 18th Jul 2013 12:47pm
x-isle
As you say, may as well use free energy!
I originally put it on for a 7 day camp on top of Alp D'Huez for the Tour de France (strangely enough that's today!), but have yet to actually get over to watch. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #252147 18th Jul 2013 1:11pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Some excellent advice and links on this chaps Thumbs Up
Defo solar is the way I'm going I looked into a 3rd battery but space is limited on the 110 for a permanent install and I don't fancy changing the aux battery whilst camping as its tight with my under seat setup.
As said on my post I don't want fixed panels as they will get in the way on the rack so any advice on the eBay setup or should I make up my own foldable set using two say 100w panels and a controller with the ability to expand the system later?
Cheers. Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #252151 18th Jul 2013 1:24pm
For occasional use, I have a 50w panel that has it's own stand and security cable attached. I plug it in to the permanently live 12v socket that I've added by the rear speaker and padlock it to the tow bar or similar. Darren
Post #252156 18th Jul 2013 1:44pm
ARC99
We have just got back from a weeks caravaning in deepest North Yorkshire without the use of 240v supply.
We use a 43 watt solar panel which is connected to 2 x 110v batteries through a regulator.As e didn't need the vehicle during the day the solar panel lived in the roof of the Land Rover to do away with the constant "chase the sun" routine.
Can I add a word of caution if permentantly fitting solar panels to the roof of a vehicle or caravan/motor home.
A good friend who has a 110 for his business and it is kited out with a bank of batteries and a converter to give hime 240v in remote areas is on his third set of panels as they do not like hail stones. Don't make old people mad.
Richard
Post #252160 18th Jul 2013 2:08pm
Page 2 of 2 <12
