Home > Maintenance & Modifications > Adding heated seats...help please
Clemmo
Ok...
So I have put a couple of 2012 XS Seats in my 2010 Puma HT.
they are heated and the loom is under the squab.
I have two genuine LR Heated Seat Switches.
Can anyone advise how I go about hooking these up?
All advice welcomed Very Happy
Thanks
Clemmo
Post #247601 29th Jun 2013 1:55pm
Clemmo
Anybody?
Post #247718 30th Jun 2013 7:44am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Some good info here, I'm sure there is more on the forum...
http://www.defender2.net/forum/topic10705-180.html
Simon
Post #247721 30th Jun 2013 8:08am
GUM97
I think Matt at FCX sells a wiring loom for them, makes things much easier Thumbs Up An engine to TDi for!
Post #247724 30th Jun 2013 8:14am
Thanks Gum,
Yes, we had designed a totally plug and play loom for hooking genuine seats to genuine switches.
It's not cheap at £120 delivered but features the correct plugs and clips for the under seat connection, the correct plugs for the window switches and all other connections are 'plug and play' with no crimping / soldering etc required.
Is yours a 2.4 or 2.2 ?
Post #247753 30th Jun 2013 11:44am
BigWheels
Heated seats with the Puma a/c, are the 2 fitments I use most, & have never regretted buying. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #247770 30th Jun 2013 12:42pm
RRUK
Simon
I am honoured to be mentioned! Bow down
Yes, I did the same, and it's a well worthwhile thing to do. Hope my thread helps. Thumbs Up 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #247778 30th Jun 2013 1:15pm
Killer90
Site Sponsor
I have had quite a few landys down for lights wired to genuine switches, exactly the same loom for the rear of the switch as is the heated seats Thumbs Up
 CSK Automotive
www.cskautomotive.co.uk
Post #247797 30th Jun 2013 3:56pm
You can do it cheaper, it all depends if you want it to look like its factory fitted ....
Our kit has been manufactured to precisely fit the Puma:
Fitting couldn't be easier, plug in the two seat switches (supplied in kit)
Remove plug from rear of hazard switch and plug it into our loom
Plug our loom into rear of hazard switch
Run cable protected in convoluted sleeving under carpet, through new hole in gear box cover (we supply grommet)
and through existing grommet into under seat box drivers side.
Slot our prewired, fused relays onto factory position,attach earth to factory position, slip live under factory position connection.
Bring drivers side seat connector through factory hole, we supply grommet and clip to secure socket
Repeat for passenger side.
No soldering, no scotch locks, all plug and play
Post #247804 30th Jun 2013 4:21pm
Clemmo
[quote="Go Beyond"
Is yours a 2.4 or 2.2 ?[/quote]
Matt..mines a 2.4...why?
Should this say " window switches" ??????
Clemmo
Post #247897 30th Jun 2013 9:48pm
Hi Clemmo,
We've built the kit for the 2.4, the 2.2 has a different layout under the drivers seat and I haven't got around to measuring for that one yet.
Post #247926 1st Jul 2013 5:46am
Full details on our kit here:
http://www.defender2.net/forum/topic22251.html
Post #256680 6th Aug 2013 11:10am
