![]() | Home > Maintenance & Modifications > Adding heated seats...help please |
| Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1324
Anybody?
Cheers |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
Some good info here, I'm sure there is more on the forum...
http://www.defender2.net/forum/topic10705-180.html Cheers Simon |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
I think Matt at FCX sells a wiring loom for them, makes things much easier
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Thanks Gum,
Yes, we had designed a totally plug and play loom for hooking genuine seats to genuine switches. It's not cheap at £120 delivered but features the correct plugs and clips for the under seat connection, the correct plugs for the window switches and all other connections are 'plug and play' with no crimping / soldering etc required. Is yours a 2.4 or 2.2 ? |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Heated seats with the Puma a/c, are the 2 fitments I use most, & have never regretted buying. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
I am honoured to be mentioned! Yes, I did the same, and it's a well worthwhile thing to do. Hope my thread helps. 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
I have had quite a few landys down for lights wired to genuine switches, exactly the same loom for the rear of the switch as is the heated seats
Click image to enlarge CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
You can do it cheaper, it all depends if you want it to look like its factory fitted ....
[URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Our kit has been manufactured to precisely fit the Puma: Fitting couldn't be easier, plug in the two seat switches (supplied in kit) Remove plug from rear of hazard switch and plug it into our loom Plug our loom into rear of hazard switch Run cable protected in convoluted sleeving under carpet, through new hole in gear box cover (we supply grommet) and through existing grommet into under seat box drivers side. Slot our prewired, fused relays onto factory position,attach earth to factory position, slip live under factory position connection. Bring drivers side seat connector through factory hole, we supply grommet and clip to secure socket Repeat for passenger side. No soldering, no scotch locks, all plug and play Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
[quote="Go Beyond"
It's not cheap at £120 delivered but features the correct plugs and clips for the under seat connection, the correct plugs for the window switches and all other connections are 'plug and play' with no crimping / soldering etc required. Is yours a 2.4 or 2.2 ?[/quote] Matt..mines a 2.4...why? Should this say " window switches" ?????? Cheers Clemmo |
Hi Clemmo,
We've built the kit for the 2.4, the 2.2 has a different layout under the drivers seat and I haven't got around to measuring for that one yet. |
Full details on our kit here:
http://www.defender2.net/forum/topic22251.html [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
