Home > Maintenance & Modifications > Mods done on my Defender which LR should have had as OE.
Page 2 of 2 <12
BigWheels
My Puma has intermittent front wiper, but same for the rear window would be nice.
Heated rear window & a wiper option for double cabs & single cabs. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #247275 27th Jun 2013 6:28pm
farmer giles
i was refering to the variable intermitant wiper relay mod, big wheels Ģ10 easy install Thumbs Up
Post #247392 28th Jun 2013 8:33am
landybehr
BigWheels wrote:
My Puma has intermittent front wiper, but same for the rear window would be nice..
I, as most of you I guess, have changed the front wiper relais to the programmable one from Volkswagen. Does what I want from it. Why they couldnīt make it adjustable, like it was on the RRC 25years ago - cannot understand.
I tinkered with putting the now-unemployed front relais to the rear door. There is an instruction on the net. Looks easy enough. But in the end I concluded I have never faced weather conditions where I needed a rear wiper to act regularly al 10seconds. If I turn it on manually itīs only very occasionally. And most of the time Iīm annoyed be the wipers scratching the rear screen when I do not need to look through it, be it intermittend or continuously wiping. So in fact - I might do the very opposite: change the switch in the dash for a push-button (? how else do you call the switches which do not stay in a "on" position and have to be depressed another time to be "off" again). Then Iīll only have to press the knob once to wipe the rear screen once which is all I need.
Post #247441 28th Jun 2013 1:19pm
Page 2 of 2 <12
